70' monte carlo rearend
360demonRT
381
central Ky
I may be able to get my hands on a 70 monte carlo 8.5, i know i have to get different control arms. will have to shorten my driveshaft, and is there any difference in the width drum to drum? will everything hook up the same as the stock 7.5?
Jon Corey
kevind
868
Whitley City KY
Should be the same as 68-72 Chevelle. 5.5 back space should be close thats what I ran when I had a 12 bolt in My car.
DOUG213XRJ
4,671
West, MI
Jon Corey
70 Monte carlo 10 bolt should be a 8.2 .
malibulvr
1,929
Pensacola, Fl. 32526
Not worth your time IMO to do the swap. The pinion size and spline is almost the same small size as the stock 7.5. I have one of those same rear ends laying in my backyard that I can't give away! I bought it thinking it was an 8.5' and suprise, I was wrong! Don't know where you are located but down here good 12-bolt Chevelle housings can be had for around $300, but once you buy a good posi unit and ring and pinion gears, axles, etc... You are looking at lots of $$$. I bought a built 12-bolt from a friend for my car, but homestly if you are going to have to build a rearend from scratch, Go with a 9". If you look you can find a new bolt in housing for less than $400, and you can buy used stuff cheap all over the place. Only thing you would prob have to buy new would be axles. And a 9" is prob a lot stronger than the the 12-bolt too. I know someone near hear with a full race '72 Chevelle 8.5" 410-bolt with good axles, spool, pro gear(4:88), Cclip eleim, and Aerospace brakes with very few runs for about $800.
360demonRT
381
central Ky
going tomorrow to pick up a complete Gbody length 9". will have to have the spring perches and mouns welded on. though. what can i expect to pay to have one welded and put together so its ready to bolt in my car?
NEW2MALIBU
920
idaho
This should help.
http://maliburacing.com/forum/viewtopic.php?f=2&t=73770&start=0&st=0&sk=t&sd=a
If you or a friend can weld, you could do this fairly easy yourself. Just an idea.
360demonRT
381
central Ky
its been about 5 years since i welded. i read that write up you did tho... if i had a welder and a place to do it i would try it for sure. hope it isnt going to cost me to much to get that 9" fabbed up. hoping i can get away for a few hundred :-#
