700R Detent
83LSWagon
592
Spring Hill, FL
So I am buttoning up the LS, and I just got the detent to connect before I can start driving it at least to work.
My question is this, how far does the detent have to be pulled? I can weld a pies on the TB to get it to pull the cable, but it wont be pulled all the way. Would I be wasting time getting it to pull all the way?
malibulvr
1,929
Pensacola, Fl. 32526
Do some lookin on here, maybe it will help. Lotta good info and diagrams in the different pages.
http://www.purplesagetradingpost.com/sumner/techinfo/techinfo.html
STROKERBU
79
Savannah, GA
All Transmission are diferent especially with the diferent torque diferent engines put out. The best way is to adjust a little at a time and drive the car to see the shift points. You want it to shift from 1st to second between 10-15 mph under normal throttle. A detent cable that is adjusted to tight will cause the transmission to hold the gears longer than needed and may cause damage to the transmission. Good luck.
83LSWagon
592
Spring Hill, FL
I think Ive got it. Dont really like the downshift points. but i know the cable is being fully pulled. I'll get pics up later.
83LSWagon
592
Spring Hill, FL
Here is a pic of the "finished" setup, though, it still needs cleaning up.
lurchsmalibu
3,774
Lakeland, Florida
Make sure it's adjusted properly or you might smoke a transmission. :-k
83LSWagon
592
Spring Hill, FL
It shifts into second at about 10-15 mph(rough estimate, gauge is off) and pulls the detent all the way out. Sound about right?
lurchsmalibu
3,774
Lakeland, Florida
http://www.73-87.com/7387garage/drivetrain/tvcable.htm is just one of MANY explanations on the adjustment.
I did a Yahoo search for.......700r4 tv adjustment.
