gmtofd said:
Before going any further, would make sure the combustion chamber size is what it's suppose to be, meaning to take them to a head shop and have one of the chambers CC'ed. Sometimes heads turn out to be larger than they are suppose to be, due to previous valve jobs.
Good advice.
That sounds like a bargain for that set of heads. Just check the heads
before you put them in service. One of the first things that I do when a set of assembled heads comes into our shop is to lay a straight edge across the tips of the valve stems. If there is a lot of variance from end to end then you know you could be headed for trouble. With most modern equipment used today to machine heads, the stem heigth can be controlled down to the thousands. You will often find a difference between the intake and exhaust steam heigth but all of the intake and all of the exhaust should be real close to the same between the sets and for both heads. If not then you'll have problems getting the R/A geometry right unless you use a bunch of different P/R lengths. Having to use two different P/R length for intake and exhaust isn't all that uncommon but it gets expensive when you have to use a bunch of different ones all through the engine.
Next do a quick check for valve leakage. Pour a small amount of liquid around the valve seat area and blow compressed air in the runner. If the valves are leaking the bubbles will show you how much and where.
Next check
all of the bolt holes. You don't want to be repairing these after you get them bolted on.
Be sure you put a straight edge on the gasket surface. If the heads have been cleaned up using a Scotch-Brite pad then just bite the bullit and find a shop that uses a CBN mill and have them re-surfaced.
Hope this helps
Donny
