79' malibu project thread
r_d_3
125
67
28
29
New Jersey
I also started cutting out the rear wheel houses to do mini tubs, hopefully ill be getting some headway on that this week.
  • Like
Reactions: melloelky
r_d_3
125
67
28
29
New Jersey
Got the first tub formed pretty nice and tacked in last night, I'm feeling good about how its turning out so far. Certain spots are a bit troublesome to weld but I'll figure it out.
r_d_3
125
67
28
29
New Jersey
Is that the OEM collapsible steering shaft with different ends attached?
[/QUOTE
The bigger DD shaft is from an astro van with a new U joint welded on, the other end is 3/4 DD shaft from amazon that i cut to length with a u joint welded on, but if you have a stock gear box and column an astro van shaft should bolt right in and they have U joints on both ends from the factory.
r_d_3
125
67
28
29
New Jersey
I thought the Astro van shaft would clock the steering wheel 90 degrees. You avoided that issue by welding your own joint on the upper shaft.
not 100% sure on if it clocks it or not, i needed to do the upper to connect to the Motion Raceworks column. and my lower section to have the right splines for a manual gear box
r_d_3
125
67
28
29
New Jersey
Started mocking up the fuel sump, plan on welding that in this week. 3/4" npt fittings for ALL the fuel.
