79' malibu project thread
shoedoos
156
12
18
good thinking on the adjustable shock mounts.....if it were me, I'd be moving them as far outboard as possible for more stability on the street.....
  • Like
Reactions: r_d_3
r_d_3
125
67
28
29
New Jersey
started welding on the coil over brackets to the housing last night
shoedoos
156
12
18
bit late now......have you checked the bolt in the lower control arm bracket can be moved up and down all those holes?
shoedoos
156
12
18
^ wasn't talking about the adjustability.....more that the shock bracket might interfere with being able to remove the bolt from the lower control arm bracket....
r_d_3
125
67
28
29
New Jersey
ooohhh yeah ill be fine there, ill just put the bolt through from the other side and the nut on the coil over bracket side
shoedoos
156
12
18
^ might want to try that with the brakes installed first.....remember all that adjustability is so you can quickly change things at the track etc.....if its a pain to do and takes three people to remove a bolt, then things get tricky....
r_d_3
125
67
28
29
New Jersey
yeah you are right on that, but also hopefully the lca angle doesn't need to be changed very often once the car is dialed in, I guess track conditions also will play into that as well.
