79 malibu rear end
tommi3520
54
Hi guys
Now its time for a rear end on my 1979 2 door malibu, i snapped an axle because of wheel hop and i see the casing is in bad shape so instead of wasting money on this i have been offered to buy a 8.8 rear from a ford explorer, Any infos on that?, Maybe the ford soes not fit because its longer but i have to mesure that. Please feel free to add some notes if you have any!
thanks!
Tomas
bowtie81
5,008
sarnia, ontario canada
Hey Tom
Do a search on the site for the 8.8 conversion, they are getting popular for g bodies. You'll def need control arm swap.
dwkohout
529
Albany,MN
The explorer rear uses leaf springs so no mounts for the 4 link.
tommi3520
54
Thanks for pointing me in the right direction. Im gonna answer myself for others that might view this thread, Here are threads that i found:
I live in Iceland so buying control arms or some kits to go with the mustang rear end is expensive, so my plan was to take the 8.8 and my 10 bolt to a garage and have them weld all the 10 bolt ears and brackets onto the 8.8 and bolt it into place, i dont know if i have to mod the driveshaft and i have to double check the width of the two rears.
tommi3520
54
I mesured the 10 bolt 146cm and the 8.8 explorer 150cm (where the rim ends to the drum)
So that will work i think.
What im thinking now
-is to make new holes on the axle for the bolts that hold the tire. So i can use my old rims and tires.
-use the 10 bolt drum on the 8.8. (junkjard has the 8.8. but drums are missing)or use the back plate and drum off the 10 bolt to the 8.8
Answer if anybody knows, i´ll update how this goes.
SSedan64
948
MACON, GA.
What are you going to do about the lack of UCA mounts on the 8.8"?
Welding Cast is next to impossible at a high stress point.
Could try this Truss setup option:
A few more 8.8" Info links:
I would try to find some Ford Drums & have both Axle/Drum or Disc Rotors re-drilled with GM pattern.
tommi3520
54
thanks for valuable info!, ill have the uca problem in mind!
maybe ill do this:
but ill have to talk to the garage that would do this work for me, yeah ill try to get the drums with!
Tomas
tommi3520
54
I just bought a 8.8. But now i see that the housing is not centered, the yoke is not in the middle and not even close.
My plan was not to change the width of the housing nor change axle length, just weld the brackets off the 10 bolt and put it on the 8.8
am i misunderstanding somthing or?
prairiehotrodder
1,576
Melfort Saskatchewan Canada
you should have bought a nine inch. Then you would have something to work with. A 70's ford truck 9" is the best one to get and then you can weld to the center. Get rid of the exploder diff.
