i am really curious if the 8.2 housing's are the same as the 8.5's,i was told they are the same housing wise.if that is true can i use an 8.5 carrier and gear set up in a 8.2 case?
i assume the carrier and pinion bearing are a different i.d and the yoke is 30 spline but
other wise will they interchange?
