'93 T-56 to LSX series motors
clyde
Member
Jun 14, 2007
8
Can anyone tell me definitively what is required to run a T-56 from a 1993 Camaro behind a LSX motor? I know LQ-9s have a different crank flange depth as well, so any guidance there would be deepl yappreiated as well. Thanks.
If you are running the stock T56 bellhousing + hydraulics, I believe you would just need the same adapter used to adapt a Saginaw, T10, Muncie, etc. to an LS motor.
http://www.ls1tech.com/forums/conversions-hybrids/1081557-gm-extended-pilot-busing.html
More specifically, http://www.ls1tech.com/forums/11237712-post8.html
