advice
got a bare 350 sbc laying around with some gm aluminum 58cc heads and a weiand 144 blower,just wondering on some parts that would make some good power,i know low compression is a key in having a supercharged motor but im not to knowledgeable on this subject...any help would be great...trying to get something in the bu' for the summer...thanks
anyone!!!! any help would be great,im not to engine savvy so i dont know what parts to get to make some power..herd low compression,forged crank and pistons and a nitrous cam works good with the blower,wondering if the 58cc gm aluminum heads i have are not good enough and if i should keep the motor at stock 350 or stroke it...any help
sheldonw
62
if you run around an 24c inverted dome the pistons about .005 in the hole a .039 thick head gasket you will be just over 9 th 1 compression which you could run about 6 lbs boost on
