Air bag pressure?
Garage Hound
512
Independence, MO
Night Stalker said:
Garage Hound said:
WOW. You guys are running these things pretty stiff. I tried mine that high once and the car wouldn't hardly squat into the launch and was all over the place.
My suggestion for a starting point: 7.5 lbs DS / 12.0 lbs PS then test, check psi, test, check psi, etc.
Above is using CE 3-ways and stock (new) springs w/ 13.5 lbs in the MT Drag Radials.
Best for my set-up anyway.
But how hard are you launching and what spring are you running now..???
There is a difference in running a 13.0 car to a low 11.-10's.. ;)
Valid point.
stafford
545
Tuttle Oklahoma
I know it is late on the post, but I run the trick springs in the back with one air bag in the right, none in the left, CE 3 way shocks set at 50/50. If my wife is driving I put 6lbs. in the bag. she leave around 2000 rpm and has a 1.50 even 60ft. If I drive I will put 15psi in the bag and I will load the converter at 3500rpm (better reaction time) and I will cut a 1.51 60 ft. If I try and leave at what my wife leaves at the 60ft will slow down to 1.54's and my reaction time sucks) I figure it slows down because I weigh a 150 pounds more than my wife.
Tony
