any one have a lower control arm frame brakcet start ripping
got a g body with the pass side lower control arm brakcet begining to rip off the frame any one ever fix this and how did they do it???
Supe
15,116
Charlotte, NC
Bend it back to where it needs to be and weld it back. Either cut a bracket to reinforce the backside of the mount, or run a tubular crossmember across the back with two pieces of tubing that branch off and run to the backside of the mounts. A lot of guys go the crossmember route and incorporate a rear driveshaft loop while they're at it.
87montess
169
PHILLY
does anyone make a rear crossmember
Supe
15,116
Charlotte, NC
Plenty of cut to fit ones out there. Comp Engineering, ART, etc all probably have them.
yea i was gonna heat it up and pull it back in to spot and plate it then runa crossmember to tie it into just wonder what every one else was doing.
C LOWERY
506
Bates City, MO
I did this BEFORE i started ripping mine off but the fix could work for you.
red barn
628
Syracuse, NY
Mine wasn't ripping from the frame, but here is how i braced it
whats with the round tube on the control arm??
red barn
628
Syracuse, NY
The edelbrock tube just braces the LCA mount from pushing out and ties into the upper mount.
The other tube.......
well.....
it is a low buck anti-roll consisting of a ladder bar crossmember welded through the lower control arms. real low tech and I am sure it sees a tremendous amount of force. It was meant to be temporary but it is still in the car
