The problem I have is both my front calipers are not releasing very well. The more you use the brakes the tighter the front brakes get. Rear drums work great. Front brakes drag so bad the car slows down without gas. You can't physically push the car by hand. I've got a line-loc that seems to operate and releases smoothly. The front caliper are upgraded to a set of SSBC calipers with stock disc's. Manual master from Wilwood. There is not a part in the entire brake system older thn 3 years. Fluid was changed last year. DOT -4 (not synthetic) Car spends more time parked than racing.
My first suspition is the line - loc is bad because both front brakes drag the same amount. Short of tearing everything apart, anyone care to take an experianced stab at where to start?
thanks for any feed back
