Astro Van drive shaft
Bad Medicine Racing
431
Grove Oak, AL
Here is something for you guys to think about. I have a GN 8.5 and I broke the stock type 3R u joint in the rear and wiped out the yoke on the rear end. So I bought a Strange 1350 yoke. I went out scouring the boneyard and guess what? The shaft from the Astro uses a 3R u joint at the transmission and a 1350 at the rear end. It is around 1" shorter than my previous shaft, so I got a "long" slip yoke for my transmission, and now I can use a readily available junkyard drive shaft. The slip yoke had to be shortened a little, but that is no problem with a chop saw, band saw, or sawzall.
Combo is SBC, short tail TH400, and GN 8.5" rear, all in stock locations, with the Jegster bolt in crossmember.
I don't know much about that drive shaft, but I don't know if I'd trust a stocker shaft for racing...
Bad Medicine Racing
431
Grove Oak, AL
Preacher said:
Alum or steel? So you have it in, using it? No problems?
Steel. None as of yet, but I ran a shortened S10 driveshaft for a LONG time. I would still be running it had I not broken that U joint and ruined the shaft. They are not the 3" small shaft that G bodys come with. They are 3" for a few inches on the ends, and the majority of the shaft is 3.5".
I'm sure it's not the best idea, but until I twist it into a pretzel, I will be running it. I just wanted to point out a readily available shaft that with a little thought could be used in a G body.
