Back rim size will it work
Little Pro St
73
CT
Will a 15x8 rim with 4.5 or 5.5 back space on a 28x10.5 slick on a stock suspension 10-bolt 8.5 rear? Or what back space on a 15inch rim would work?
For 1980 malibu trying something alittle differnt with No notching looking to for weld pro stars so one rim can be for slick and the other for drag radials.
Little Pro St
73
CT
There is a guy that I met he has pro stars that are 15x8 with 3 and 3/8 back space what ever that mean i don't no if it will fit
gonna have to either cut or roll the lip w/ that tire though, unless your cars sitting tall
Little Pro St
73
CT
I did cut the lip and it sits level i want to buy it only if I no for sure that they will fit!! thanks
Supe
15,116
Charlotte, NC
It will fit with the lip cut on the 3 3/8, but will be pretty close to the outer lip. To run 4.5 with a stock width rear, you need a spacer or a notch.
smitty84monte
108
Durand MI
15x8 with 4.5 back spacing, 7/16 spacer with a et drag 28x10.5 with clearance, or a bfg drag radial 275-60 with all the clearance you could want
That's what I used to run before the frame notch, with the 28x10.5. Now I just don't use the spacer.
