Bbc heads
silver79
88
whitewater, WI
So I have a tall deck 8.0L bbc as advertised by gm industrial. Mine was in a generator made by Generac and has some interesting parts. Scat crank, nice rods, speed pro flat tops, 1 piece rear seal. It looks new inside (ran on propane?) My question is about the heads. They look like a "fastburn" style chamber and has the 2.06/ 1.725 valves. I haven't cc'd the chambers yet. The only casting # is a Generac p/n. They look like oval ports. Im going to try to
get 600 h.p. naturally aspirated from this combo. Do you think I can do it on these heads with some port work?
prairiehotrodder
1,576
Melfort Saskatchewan Canada
i think 600 hp is obtainable with nearly any BBC head. However the whole combo needs to be set up well. It will not be a real tame combo. Probably a solid roller cam with fairly high compression. Also much bigger valves and high quality parts to work with that roller cam.
G Body George
New Member
Sep 6, 2021
3
Looks like those could be the peanut port late model vortec style heads , Do they have a bolt in rocker or stud mount style rocker , A picture of the top side of the head would help . Once i see this i could give more accurate advise or possible a casting number .
