big block questions
elcaminoss84
336
Oklahoma
I was reading the tech area about how to do a big block swap into a gbody. but im not sure which oil pan to use? also should i just get like a stock style oil pan or like a street/ strip pan or does it make a differance?
malibu795
1,496
4
spgfd ohio
need to be for a car st'ck car is 4qt
elcaminoss84
336
Oklahoma
also how do you tell the difference between a tall deck and short deck big blocks ? the big block i got was out of a one ton truck so is that a tall deck or short?
bracketchev1221
1,111
Mountville Pa
Tall decks were only 427 engines. And that was in larger commercial trucks.
SSedan64
948
MACON, GA.
366 & 427 are Tall Decks.
Short Deck = 9.800"
Tall Deck = 10.200"
.400" Difference in Deck Ht.
Water Pump mounting holes are right next to the Deck surface on a Short Deck block, so you can tell easily by that.
Tall Deck & Short Deck Pics:
TURNA
6,028
Socialist NY
There was also a 1 or 2 year 454 tall deck
i believe the casting # is 10114182
best to take the numbers off the block and post them
elcaminoss84
336
Oklahoma
after seeing the pictures i went and looked its a short deck and checking the engine block number its a 82 454 truck motor with the peanut port heads.
SSedan64
948
MACON, GA.
Turna I think that's an Internet rumor spread around.
The last 454SS P'up I owned had that 10114182 Block casting # and it wasn't a Tall Deck. It was a Gen-V 4-Bolt Block tho' & they're Truck only Blocks.
There're several 454 Bowtie Tall Deck Blocks.
zapc
14
i used the stock oil pan from the 2 wheel drive donor suburban and it fits perfect, so truck oil pans work, i think maybe the 4x4 pan may be different and if not then all truck pans work
Redline396
265
clifton, nj
fyi....big block car or truck oil pans are 5 qt capacity.....and fit the g bodies......also make sure to use the right motor mounts......i mean the matching frame to motor mounts........early f body style work.....70 s to 81........
