flatblack79 said:What is everyone using for bolt ons. I am running a class where i cant notch the frame or cut the body any. Running a 275/60/15 BFG Street radial. What can i bolt on to make it hook up?
Hello
I noticed that you are looking into making a vehicle hook! And I would suggest to you a lift bar set up. Allows you to adjust the instant center of the lower control arm. By adjusting the LCA more parallel to the ground eliminating any wheel hop issues and increases your traction performance. Below is a link.
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_60_72&products_id=83&zenid=4o3pa4snrgpj7hp3l5katkrpf2
And another suggestion for you would be a set of adjustable upper control arms to fine tune the rear by allowing you to adjust the pinion angle. Below is a link.
http://www.umiperformance.com/catalog/index.php?main_page=index&cPath=8_60_71&zenid=4o3pa4snrgpj7hp3l5katkrpf2
And in conclusion for the last part I would suggest is a set for frame braces. They protect the upper and lower control arm mounting locations. So they don't bend or crack. If you have any other questions feel free to ask. Below is a link. To show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_60_197&products_id=350&zenid=4o3pa4snrgpj7hp3l5katkrpf2
Thanks Again
Brad
