The reason that a spool is dangerous is that it breaks parts. It puts too much stress on parts when turning corners because there is NO slip at all when you turn. I have had customers break all of the studs off of their axle, I've had them break axles and I've seen wheels cracked by using a spool on the street. I've never seen any of this from using a locker on the street. I've had a Lock Right in my daily driver for 14 years and I've put 140,000 miles on it with no probllems. A locker will allow the wheels to turn at different speeds when you turn, so the stress is not there. I will no longer install a spool of any kons in a customer's car if it's going to be used on the street.
