Car dying on me
Al
2,018
Harker Heights, TX
Today I was drving the Elky when it started acting like it was running out of gas. It did it for a couple of minutes and then cleared up. A little bit later it doing it again, but to a lesser degree. It cleared up but after that if you hit the brakes at all hard it would die or try to die on me. If it's sitting still it will idle fine. I'm thinking it may be one of a few things: a. Crap in the fuel line b. Crap in the carb somewhere c. Fuel pump going bad. Any ideas on this one? Thanks.
Add some fuel additive for water.
Run some Sea Foam through the carb and in the tank.
Replace the filter.
Check for vacuum leaks.
