ceramic coated headers and breaking in a cam ?
DOUG213XRJ
4,661
West, MI
Why is breaking in a Cam so bad with Ceramic coated headers ? is it the heat ? It was a PTA removing the headers, installing factory exhaust manifolds then after the cam is broke in reinstall the headers .
Thanks Doug
Killerdave8813
885
Cincinnati,Ohio
I never had any issue with my Dougs ceramic coated headers breaking a fresh engine with a new camshaft, just make sure your timing and jetting are correct so it doesn't get lean hot (bad anytime) and it helps to have a couple box fans blowing on the radiator as extra insurance, and obviously keep a close eye on your guages!
A Aftermarket Brake Pads? Ceramic? Carbon Fiber? Wheels/Tires/Brakes Technical 4
Jayz79 Powder coated frame question Autobody/Paint Technical 1
grizwald power coated welds Autobody/Paint Technical 4
C Vega LS Swap Headers LSx Tech 0
K Afr 210 eliminators and headers problem Drivetrain Technical 3
D SBC HEADERS? ???'S Drivetrain Technical 5
7 budget ls swap headers LSx Tech 1
S Ls swap headers LSx Tech 2
8 V6 Factory stainless steel tubular headers for G body V6 Tech 1
8 4 speed headers...again Drivetrain Technical 5
M Which Headers will work with 1" setback motor mounts LSx Tech 1
R Do pace setters headers for a 4th gen camaro fit a GBody? LSx Tech 3
P Fender exit headers Drivetrain Technical 0
D Best SBC Shorty Headers(ANGLE PLUGS) Drivetrain Technical 0
sbmalibu schonefeld headers? LSx Tech 4
B 4 speed swap, what headers? Transmission Technical 4
M 3.3 headers V6 Tech 1
8 headers with a 4 speed Drivetrain Technical 17
Jason80MC AC with Headers Drivetrain Technical 1
45CHI trouble with my pacesetter headers LSx Tech 9
B Twin turbo headers BBC Power Adders 2
81malibu329 Headers with a column shift LSx Tech 1
D Headers & paint Autobody/Paint Technical 11
Kansas Bu Wagon Jegs LT Headers and 2.5" Exhaust. Drivetrain Technical 2
7 Big Block Shorty Headers? Drivetrain Technical 8
S headers LSx Tech 7
R Hedman headers fit with my old transdapt mounts! LSx Tech 15
M shoenfield headers sbc Drivetrain Technical 6
G 87 cutlass supreme bbc headers Drivetrain Technical 10
malicad Hooker LS manifolds VS LS headers LSx Tech 5
ralphl mad dog headers for pontiac 455 in g-body Drivetrain Technical 0
S Schoenfeld LS headers? LSx Tech 5
S 67-69 camaro headers in gbody. Drivetrain Technical 0
G big block headers Drivetrain Technical 15
464elcamino headers in a 82 wagon Drivetrain Technical 3
M Schoenfeld Headers - Question Drivetrain Technical 2
D REMOVING RUST ON HEADERS ???'S Drivetrain Technical 5
unclepudge Adding headers with factory air. Drivetrain Technical 4
S Installing headers Drivetrain Technical 7
J Turbo headers??? Power Adders 20
M headers! LSx Tech 0
7 How to install Hooker Super-Comp 2242 Headers Drivetrain Technical 0
S Stickey for LS headers/mounts? LSx Tech 5
1980elcamino 229 headers V6 Tech 6
J Patriot BBC Headers as Another Option Drivetrain Technical 1
fatkid patriot exhaust street stock headers? Drivetrain Technical 0
Bubuseventy8 Edelbrock headers LSx Tech 1
C shorty headers for gm 3.8? V6 Tech 3
k9 Help! Help! Need headers Drivetrain Technical 10
sbmalibu other f body headers!! LSx Tech 13
Similar threads
