choke voltage - 4 volts?
79 surfwagon
335
Texas
my choke quit working on the 1980. the lead wire is only reading about 4 volts with the ignition switch 'on'.
What voltage reading are you guys getting on your cars' choke lead?
I found the wiring diagram in this forum... super helpful. I hope to get my reverse lights going and repair/get 12 volts to my choke wire this weekend.
Thanks in advance for your help!
You should have 12 VDC on every stock circuit. There's no ballast resistors on these cars...
79 surfwagon
335
Texas
thanks guys. I plan to chase the choke wire back to its source and find why I'm not getting 12v.
Check the oil pressure switch. It feeds the choke heater. It may be a source of resistance, but not enough to make the oil/check engine light come on.
malibu101
441
Walnutport PA
Agreed.
I was going to ask...Are you checking the voltage with the engine running?
If the engine is not running (to close the oil pressure switch) your readings at the choke really don't mean too uch.
79 surfwagon
335
Texas
thanks guys. My Dad and I chased the problem to the oil pressure switch. Specifically, it's the plug for the switch... the fit is loose. With the car running, and holding the plug firmly onto the oil pressure switch, we get 12volts to the choke lead wire at the carburetor.
Again, thanks for all the help on this.
