Cut ft coil springs or get new ???
Sikmalibu
744
Central NJ
I have recently took apart my front end and I never liked how high it sat. I am debating on just cutting a 1/2 coil out and seeing where that will put it or just get a set of Trick springs that will bring it down. I just dont know if the new big block is gonna make the car carry the wheels and I dont want it comin down on the oil pan. I plan on extending the snubbers on the lower a arms just for insurance but still. What do you guys think???
DFWMalibu
999
Dallas,Tx
you could also just install a set of v6 springs.... alot of people run them and it will definately lower it....
Chris K.
Sikmalibu
744
Central NJ
I actually have a brand new set of v6 springs that I was thinking of using. But I thought I heard someone say they are to spongy with a big block car and will probably bottom out.
cutlass389
684
NC
Alum. or iron heads? If it was originally a V8 car then the sag might be just right with a BB. Regardless, I would wait until it's actually in there for a bit to determine which way to go.
Sikmalibu
744
Central NJ
aluminum heads. When it was in the car before there was still like 3" from the tire to the fender. And I would like to bring it down like 2" but not if my car is gonna come down to hard an break somethin....
toxicbu
616
romeoville il
my bu came with a v8 305 - i cut 1coil ring out , the ride height was 1in lower. it stayed that way for 3 years and it's now starting to sag (i dont drive it on the street track only) im going to try v6 springs
