i know its shorter but can i use the 1 from the 89 jimmy im taking it from?
B birdmansmalibu Member Aug 20, 2010 6 0 0 Aug 21, 2010 #1 i know its shorter but can i use the 1 from the 89 jimmy im taking it from?
bustedknuckle Dragway Regular Mar 4, 2008 959 0 16 St. Louis-Missouri Aug 27, 2010 #2 this question might get more attention in the v6 tech section
TURNA MalibuRacing Junkie Jul 6, 2003 6,028 1 38 Socialist NY Aug 28, 2010 #3 if you are just swaping the engine there is no difference in the driveshaft lenth whats in the car now will work the trans will still sit in the same spot on the crossmember
B birdmansmalibu Member Aug 20, 2010 6 0 0 Sep 18, 2010 #4 i want to use the 700r4 thats already attached to the 4.3
TURNA MalibuRacing Junkie Jul 6, 2003 6,028 1 38 Socialist NY Sep 18, 2010 #5 if your using a 700r4 trans and you had the orignal metric 200 or 350 trans in the car then you need to cut the driveshaft 3 inches
B birdmansmalibu Member Aug 20, 2010 6 0 0 Oct 9, 2010 #6 ok to be more clear, i'm putting the 4.3/700r4 in the car.
