drivetrain help turbo 400
blu402mally
2,482
phila,pa.
have an 8.5 rear for my mailbu/along wiith the driveshaft....the rear & shaft came out of a car with aturbo 350 trans...can someone tell me what size front yoke I need to use this shaft with my turbo 400 trans..
TURNA
6,031
Socialist NY
Depends on what 400 you have.
There are 2 different car size tailshafts both same spline but the thickness is different.
So the yoke thickness can be different as well.
I do believe splicer makes a seal so that you can use the smaller 400 car yoke in the larger hole tailshaft though
Best to grab the yoke that was in the 400 if you can
blu402mally
2,482
phila,pa.
thanks Turna for your reply...I do believe this a short tail 400 & I got this trens a coulpe years ago and no yoke or shaft was with it
bu-berry Help!!! drivetrain noises? Drivetrain Technical 9
T Drivetrain vibration Drivetrain Technical 6
J 82 chev elcamino v-6 to v-8 drivetrain swap questions!! Drivetrain Technical 1
reel01 Carb help Advanced Technical 2
DopeSick78 Front Trick Help! Suspension Technical 8
L Need help with radiator hose Drivetrain Technical 4
V Camshaft help Drivetrain Technical 1
8 Distributor wiring help Electrical/Wiring Technical 2
ghostrider 80 malibu help Suspension Technical 2
M axle/disc brake swap help Wheels/Tires/Brakes Technical 2
E replacing all brake lines help with distribution block Wheels/Tires/Brakes Technical 2
L Steering Column Help Needed Interior Tech 0
jking78 Brake lines help Wheels/Tires/Brakes Technical 2
7 Cross member help Transmission Technical 3
M front end help Suspension Technical 1
7 Bump steer help Suspension Technical 8
B Spring help Suspension Technical 3
78_Landau Need help... BAD wheel hop!! Drivetrain Technical 8
80driver No spark , can't find out why. Help!! Electrical/Wiring Technical 22
J LS intake help??? LSx Tech 3
M BBC to 6.0L LS swap help. LSx Tech 3
BillySS pitman arm help needed ASAP Suspension Technical 4
D side view mirror replacement help Autobody/Paint Technical 2
D 700R4 casting id help Drivetrain Technical 4
T removing door glass help Autobody/Paint Technical 3
7 Front coil overs in gbody cutlass..no travel..help!!! Suspension Technical 11
F gn gas tank and sending unit help EFI Tech 6
prostreet66 powerglide HELP Transmission Technical 2
B need help on pinion offset Drivetrain Technical 2
Y Rear tire size? 80 Bu HELP PLEASE Wheels/Tires/Brakes Technical 2
blown 78 Need some cam help LSx Tech 1
F Need swap help. 4.8/5.3 into 1980 Malibu LSx Tech 4
D Horn button help - Monte Carlo steering wheel Interior Tech 5
prairiehotrodder 12 bolt help Drivetrain Technical 2
R rear end/suspension cracking sound need help Suspension Technical 2
U Trim help ? Autobody/Paint Technical 5
R 9 inch options. Need help deciding Drivetrain Technical 5
DOUG213XRJ help me with electric fan(s) installation. Electrical/Wiring Technical 3
1978_Andy_Project TH350 won't go forward. Help? Transmission Technical 8
J Need help/transmission question Transmission Technical 5
D 4 wheel disc brake setup help! Wheels/Tires/Brakes Technical 5
G Fuel system help on my lq9 LSx Tech 4
D Blower fan stopped working- need wiring help Electrical/Wiring Technical 5
9 79 Malibu Carb to EFI Fuel System Help EFI Tech 8
1978_Andy_Project Help with starting system Electrical/Wiring Technical 19
7 Throttle cable too short on sbc g body help!! Drivetrain Technical 7
7 headlight conversion, 1980 malibu h4 bulb HELP?? Electrical/Wiring Technical 4
7 header help pics please would be great Drivetrain Technical 17
B Pinion angle help please! Suspension Technical 7
F manual to power windows help needed Interior Tech 4
Similar threads
