Finally had an out of body experience
cutlass389
684
NC
It was inevitable. I "borrowed" a 7.5" rear with mini-spool from a buddy to test my theory about a defective differential. On the first pass at the division 1 bracket finals the drivers side tire and wheel left the body to pursue a solo career thus ending my season in disgrace. He swore it had 28 spline axles in it but the autopsy proved otherwise. At least it happened right at the line instead of at the 2-3 shift.
I'm glad nothing major happened. BTW, I thought 7.5"s WERE defective rears... #-o
monzaz
704
Richfield, Oh
www.jdrace.com
Yah you have to watch stuff like that ...Especially if you go to the track often they will will watch you close and if it happens too often - they will ask you nicely to leave and not come back. ...Depending on how fast your car is.
toxicbu
616
romeoville il
i had a mini spool in a 8.5 and broke the axle end of the spool , then i was taking the rear apart sliding the pin out and cut the tip of my finger to the bone .
monzaz
704
Richfield, Oh
www.jdrace.com
mini spool is a dirt track spool system...IT IS REALLY not MEANT FOR THE STREET OR DRAG RACE TRACK. Dirt does not have the grip that asphalt does and especially the well prepped drag track...so the mini spool will survive MUCH better there...lol.
At the very least running a mini spool on the street you should have aftermarket axles too. AND if your going to spend that much on axle you wight as well go all the way and do it correctly. Jim
