fogger questions
chevy406
84
ft pierce,fl
well i bought a sportsman fogger it has been plumbed for a bigblock and i have a small block, i have a couple questions do all the fogger lines have to be the same length, would it hurt if one side on the fuel and nitrous was a 1/8 of an inch shorter on each side, what brought that question up is that the two inner nitrous fogger ports on the small block are a hair shorter than a big blocks, does it matter if the fogger nozzles are exactly in the middle of the circle on the intake, when i put the prebent lines from the big block intake and match them to my small bock intake ports they are on the very outside of the little circles, is that ok, can i put them there? or does it have to be right in the middle?, the 4 outter ports are about a 1/2 off to 3/4 of an inch from the lenght of the tubing so i can cut them down and position them perfectly in the center of the ports.can any of you nitrous experts please help. thanks
Excelerater
6,798
Memphis,TN
youll be fine......
