Ford 8.8 swap....
1BAD81BU
2,235
Whiteland, IN.
BUMP, for a good topic. I might be interested in this too. I need another rear to replace the 7.5 posi I already have. Nick
For all the guys with G-bodies you have to use a mustang or thunderbird rear because of the cast "ears" for the upper controll arms. The sn-95 rears are 1 1/2" wider 94-98. And also new-edge is wider 99-04. The best would be 8.8 out of a 79-93 mustang. I find them for $100 a pop alot around here.
*** (I may be wrong about the explorer rears)*****
-Are they leaf spring or factory 4-link? Im not sure.
I guess Im gonna try this rear, Hopefully I will pick up my next project car saturday!
Re: and...
84cutlass357 said:
what can be cool is that most weld draglites are 5x4.75 AND 5x4.5 so maybe you can muster up a set and just use diff holes and no one will be the wiser!
rob
ps---8.8 fan here
Yeah, It would be hard to notice that for sure (especially with 5/8" studs ;))
I have always been an 8.8 fan. I have seen several cars in the mid-8's with an 8.8 rear. I had one mustang that was a DR car with 33 spline axles and a spool 5/8" studs. I dont think anything would break it that is still "stock suspension" (35 spline is available have to install big ford ends)
The best part is... it is stronger than a 8.5 10 bolt (ring gear issue) may be stronger than a 12 bolt (definatly on par) and takes about 10hp less to turn than a ford 9" due to the pinion location :)
What has to be modified...
-Have to weld on spring perches
-May have to modify the LCA mounts
-Custom upper control arms (mustangs wider apart)
Nothing really different than a 12-bolt except the LCA mounts, and surely the cost of that would be offset buy the relativly cheap price for parts for an 8.8......
Longroof79
8,948
9
Gainesville, Fla.
Turbo Diesel,
Thanks for the good information. Perhaps some one could do a tech section/ article on swapping in a Ford 8.8 rear into a Malibu/ G-body...*hint, hint*
Jack ;)
1BAD81BU
2,235
Whiteland, IN.
Jack, I'll second that! Turbodiesel-Get busy! :lol: Seriously, thanks for the info.:D Nick
MalibuRacing
3,465
www.maliburacing.com
If someone wants to attempt it and document it, I'll be glad to post it in the TECH/FAQ sections. :nana_wrench:
PAHR
111
Tennessee
Some 8.8 info
8.8 Mustang, Pre 98 Ranger, Bronco II's are 28 splined axles.
8.8 Explorer, 99-current Ranger are 31 splined axles
Ranger & Bronco II's mount below the leaf springs.
Explorer's mount above the leaf springs.
Mustang's are like a Malibu, upper & lower control arms.
The tag on differencial cover will read "3L73" if it has a LOCKER, if it is an OPEN rearend it won't have the "L".
Just some FOOD FOR THOUGHT!!!
GOOD LUCK & BTW: I have 3.73 & 4.10 factory Ford gears in original boxes for the 8.8, if your interested, just drop me an email.
this does sound interesting - I've been thinking about a new (and posi) replacement for my peg-legged 7.5 time-bomb
fyi - explorer/mountaineers are leaf-spring - you can see the leaf springs on my '97
also, at least the '96 on up V8 models had 3.73 gears - so you could cannibalize it for another 8.8.. I'm not sure what gears the v6 models used or if they changed for the earlier years
