gunna be installing autometers soon, and was wondering what ohm fuel senders are in the tank factory in my 78 malibu? im sure a few of you know, any help appreciated
joye227 said:My cutlass has rally gauges and the fuel gauge is off, so I was thinking of buying and ultra lite fuel level to match my other gauges. My sending wire has a good ground. So I just ground the gauge and hook the sending wire up to the old sending wire going to the dash?
Yes, the fuel gauge will have a power and ground, and a third wire (pink, not pink and black, that is power to the cluster) will be the wire to the sending unit. Basically the fuel gauge is an ohmmeter, power (pink/black and black wires) is needed for the actual gauge, and the pink wire is the 'probe wire' that goes back to the sending unit, which is a variable resistor (aka potentiometer) that provides a ground for the 'probe wire' of the gauge. This is the same premise for water temperature, oil pressure/temperature, and just about any other gauge (besides voltmeters, ammeters, speedometers or tachomters).mean78malibu said:joye227 said:My cutlass has rally gauges and the fuel gauge is off, so I was thinking of buying and ultra lite fuel level to match my other gauges. My sending wire has a good ground. So I just ground the gauge and hook the sending wire up to the old sending wire going to the dash?
I believe the gauge will require accessory power also, so you would need to connect that to the ignition somewhere or jump off another wire. Assuming your factory wire is good all the way back, you should be able to connect to it.
