Fuel Return Line Question
Dirtyray
I am doing a swap and am wondering if on a 1980 malibu can I use the charcoal canister line as a fuel return line on my ls1 motor?
quickie70
65
Denver, CO
you can use the hard line, but I'd replace all of the rubber with fuel injection hose and the correct clamps. It *shouldn't* build a ton of pressure, but if something breaks (regulator I'm thinking), it could see 60+ PSI. Some senders also have a restricted plug (think soldered line with a teeny hole drilled in it) at the tank, so you'll need to drill that out to full dimension.
dynodanmanda79
61
37
Niceville, FL.
I would just run the vette filter and mount it close to the tank, that way you won't have to run a return line all the way up to the engine bay, I'd reccommend using braided hose too.
