Fuel System ???
Silver Malibu
47
rockford il
CutlassRacer said:
When it comes to boosted fuel systems, Aeromotive is the ONLY way to go. Pick up an A-1000 pump, and the recommended return style regulator (cant remember the part number) and then run the proper size feed and return lines (at least -8AN) and you will have a killer fuel system that will never let you down. In my experience, the A1000 does not even need the step down box to run it on the street with a carbed, blowthrough setup. The pump simply isnt having to work very hard to move the fuel so the pump doesnt get all that hot. I know of several that have been running around on street cars for years and they have never had a problem.
I dint know that with the blowthrough my friends was f.i.
8secChevy
229
Williamstown, NJ
Aeromotive all the way. Ive been running one for over a year now on the street & strip. No issues what so ever & my combo has a little over a 1000hp at the crank.
i run 850 HP, 489 stroker with 871 blower. my fuel system is an RCI 16 gallon fuel cell, a1000 fuel pump, -10 feed line, aeromotive fuel pressure regulator, 4 x -8an feed line to the gb blower carb 800cfm carbs, then -10an return line.
