future brake plans... questions
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
in the future(when i get back stateside) i plan to eventually swap to the speedway bolt on rear disks(with e-brake) for my station wagon, i also would like to swap over to the b-body fronts. first off, if the caprices came with 15" wheels, won't they fit in 15x6 front steel rally's??
second, would i need to change the proportioning valve, or could i just add that residual pressure valve?
also, whats a good disk/disk master cylinder i could go with... as well as a booster??
StreetBu
4,158
3
Upstate NY
Hey Mike, You have to get rid of the stock proportioning valve, cant use that with discs, I'd try to find one off a blazer or caprice w/ 4 wheel discs. Many choices for master cylinders. 15" front rims "should" fit, but may not-because of the spindle and a-arm change over. HTH Stay safe
MISFITmalibu63
7,163
so i did a lot of reading yesterday and went through a bunch of old posts...
the stock MC and booster is OK
better yet is the dual diaphragm 9" booster, and if you upgrade to disk rear, you can use a disk/disk MC from a 79 vette apparently.
as for everything else, you will need a disk/disk prop valve.
this is from LS6 Tommy, and its all the parts you need for the 1LE swap
Here ya go:
Spindles and calipers are from 78-90 full size Caprice, Caddy, Delta 88, and Pontiac. Typically wagon, police or with HD towing package.
Brake calipers, (1)#18-4021, (1)#18-4020
Brake flex hoses, #BH36848
Brake caliper hose bolts, #483-205
Brake pads, # D52
Brake rotors, 1LE, #5994
Wheel bearings, 1LE inner, #BR6
Wheel bearings, 1LE outer, #BR3
Bearing seals, 1LE, #19753
Hub grease caps, 1LE, #13977
If you're tearing down the steering too, here's the part #s:
Tie rod, inner, 78 Malibu, #ES2034L
Tie rod, outer, 78 Malibu, #ES2033R
Centerlink, 78 Malibu, #DS909
Idler arm, 78 Malibu, #FA1013
Ball joint, lower, 78 Malibu, #FA3000
The tubular upper A-arms required should have ball joints already installed.
heres the links for the different arms:
SPC
http://www.spcperformance.com/PROD_DIR/SPCPerf_PROD_SEARCH_DYN.cfm?cmd=Cam&cmd2=94330&cmd3=
FREE YELLOW
http://gparts.freeyellow.com/12brakekit.html
also available from FREE YELLOW is the COMPLETE 1LE brake swap
i do wonder, he says that with his upper control arms, you need to ream the spindle for the larger ball joints, is there a ball joint that we can replace his with that wouldn't require the spindle to be reamed?? :-k :-k :-k
You can't use a disc/drum master on a disc/disc setup. It doesn't move enough volume of fluid to properly operate the rear calipers.
