G-body bell housings anyone???
Meat Drapes
1,198
9
Stoutland, MO
There is such a thing as a 10.5" flywheel for a 454. I have one. Got it from GM directly. Nodular iron and externally balanced. Just a responce from a earlier comment in this thread. I dont recall the part number.
TURNA
6,028
Socialist NY
GM part number is 3963537 Flywheel ID #3935411 153 tooth 10.4"
700r4
El Coolmino
2,505
DSM IA under a green truck
Weld & drill is a great solution for a stock type ride.
If it's a performance car seriously consider the lakewood 15015 with a normal fork. No more concerns about clutch size and no more hard to find parts. And you'll still have ten toes if it suffers a violent clutch explosion. Not to mention the blocksaver plate and it's benefit. Good luck
Bar50
1,871
Tulsa, OK
I got the first one back from they gut that does all my aluminum welding. $75 to weld up the old hole, weld in a boss, counter bore and tap the new hole and surface the transmission face of the bell housing. I had to buy a special tap 13/16 - 14. I'll snap some pics and post them.
As for the stick shift, 10.5" flywheel, I have never seen one. I have a new GM performance part catalog, and the only 454 and 400 SBC flywheels listed are of the 11-12" variety. I'll double check that number, see I can score one of those flywheels.
My welder guy does machine work too, mostly repair on aluminum block and heads. He told me he could do a little better on the price if he can do several at once, to save from setting up his mill each time.
TURNA
6,028
Socialist NY
GM part number is 3963537 153 tooth 10.4" flywheel
Bar50
1,871
Tulsa, OK
Some pics of the bell housings I had altered:
Too make this all work, I opened up the hole for the fork down-ward to the rib.
I had to end up using the 12" bell housing to clear the clutch/flywheel appilcation on my 454. Mine is working fine with a normal clutch fork from a local parts store.
To make the 12"/truck bell housing work, the hole for the pivot ball was welded up, a boss was welded inside the bell housing. Upon setting up for the new lower G-body specific hole, it was going to be close to breaking through on the larger front bearing retainer hole the transmission sits in, so, I turned the outside of the pivot ball down on the lathe about .040. I purchased the special thread tap for the pivot ball. The guy I use welds them up, repairs any stripped holes(with heli-coils), decks the transmisison surface, and drills, counter bores, and taps the hole in the right spot for $75. He'll cut a break if he can do several at a time, then he doesn't have to re-set-up the mill.
I will take a pic of the opened up hole. It is probably too large, but, not that it is all in place, I'll make a template so its a smaller hole, with a tighter fit.
I also found a guy on ebay that sell a front bearing retainer that fits Muncie & Saginaw that fits the truck bell housing for like $48.
I had two 10.5 inch bell housings altered when I had the two in the pics done. If anyone wants one. Let me know.
Killerdave8813
904
Cincinnati,Ohio
Personally I have aquired a Lakewood 15015 to fit an 82 to 84? Camaro
and also happens to fit Malibus as well!! I'll be installing it next time I have the drive line apart!!But thanks anyway!!Later,KillerDave
Bar50
1,871
Tulsa, OK
Well, here is the deal, my cars will have the option of being stick shift. I had the bell housings welded up, one is in place. If anyone else wants one, I'll sell/exchange one. I was looking at the scattershield, but, it was well, more expensive than a normal chevy one, I already have a few of those. Plus, the rat motors these are behind are 6500 RPM max, with street tires. I move up to slicks, 'll add a scattershield.
I just figured if I was looking for stuff to make one a stick, surely someone else will be.
Keep me in the loop on how it all works out.
Truckedup
64
Western NY state
Converted a 81 El Camino to manual trans.Used an early 80's Camaro #627 bellhousing with a generic Chevy truck throwout fork. Clutch linkage lines up properly in a straight line,clutch action is very smooth
