Garrett
Robert1320
It may be a TO4E. You should pull the covers off and measure the major and minor dims on the Compressor and Turbine.
Most likely you will need another TO4E to feed a sbc. The honda guys like them.
Feel free to give us a shout. GM turbo set-up are easy but, many choose the a more difficult path.....
blue t
234
birmingham alabama
The best thing to do is find your goal then go from there. After you know what your goal is do some research on what it will take to get there. I have also found that if you want to make 600hp dont by the stuff thats rated for that go a little bigger. If you do this you dont have to push every thing so hard.
LuVnThE1320
15
okay so what i figured im gunna do, list number one...I plan to goahead and tear my fresh rebuit motor down go ahead and put a cast 9000 scat stroker crank, scat forged i beam rods (to make 383 minus bore size) and my buddy just gave me a set of new srp 9.1 forged pistons.(these are .60 over so is my block) any complaints about boost a .60 over? ontop of that i have my edelbrock rpm heads, edelbrock rpm airgap intake(this is a dual plane how well will it work on boost also). I only play to run 6 to 12 lbs of intercooled boost. Ima try the ebay gt45r turbo everyone is ranting about how its a descent piece.I would like to make a streetable 500rwhp is this doable.?This is my goal it should take to over the next months till around January.. I will start to make a build thread here if everyones interested. Any input is well appreciated.Thanks guys thats help so far..
LuVnThE1320
15
750 hp would be insane......500 is the goal but if it makes more totally awesome..SO ill get some pics soon and start the progress...its a 78 with m80 spoiler thats been sitting in my dads garage for the last 10 to 15 years
blue t
234
birmingham alabama
I would stay away from the ebay turbo but Im also not a big fan of the b/w stuff either. If you skimp on the turbo you will end up paying later and have enough in if for a precsion turbo. Look around on yellowbullet or turbomustangs you can always find a good deal on a good turbo. If were me I would look into a 76gts or some thing in that range.
Robert1320
You can be real close to or at 500 on pump gas d/d. Soooo why get a turbo that will only support 500-600 hp?
Bad Medicine Racing
431
Grove Oak, AL
Quick79 had some really good luck with an out of the box S475. Hard to beat for around $600 brand new.
http://www.youtube.com/watch?v=DArzD6ymMNg
LuVnThE1320
15
ok guys wish me luck ..lol..hopefully order my scat stroker 383 crank friday!!!!!!!Got pics just gotta figure out how to get some posted to start the build thread
LuVnThE1320
15
