gbody 7.5 rear end can it take power
psychomotors
896
Bonne Terre, Mo
I finally decided to go with a Powertrax. I'm rebuilding a different rearend with3.73s in it but my original rearend has 2.73s. I got to thinking that if I was to swap the old rear back in, I can transfer the Powertrax over to it. I'm also getting an aluminum support cover for extra insurance.
SSedan64
948
MACON, GA.
If you're changing Gears/Carriers in one of your Rears add a Solid Pinion Spacer in place of the Crush Sleeve. Adds strength/rigidity, the Pinion is a weak spot in the 7.5".
SSedan64
948
MACON, GA.
Any Diff Shop should be able to get you one or contact Jim member name> "Monzaz" on here, He's a Rearend builder, & I think a Vendor. I'm sure He'd appreciate the Biz.
Also Google > "7.5" Solid Pinion Spacer" and lots of Info will come up.
