Got's me a Problem!!!
All my external lights work. My problem is,........when i press the brake, my front parking lights come on, haha. I've looked in the trunk and there is no cross-wiring there, so where could my problem be?
O. D. Showtime
2,851
Regina SK Canada
Chased that problem on the son's car, turned out to be poor grounds under hood.
TURNA
6,028
Socialist NY
i had that problem on my 74 chevy pickup
I thought it was cool so i left it alone!!
Which ground was it that was poor? My main ground from the battery is a brand new cable. I'm thinking it could be under the dash(somewhere around the fusebox). But im not sure.
O. D. Showtime
2,851
Regina SK Canada
We went thru all the grounds under the hood, lite harness to core support(one on each side), one on the firewall, pass fender. Cleaned and checked them all.
I'd start with the grounds for the brake lights.
Z-man
1,058
Barnesville MN/ Fargo ND
That's not a defect, that's a feature. :lol:
383malibufiend
2,661
Lancaster PA
hahhaahaha
FIXED!!!! Had a single filament bulb in the brake light and it was causing the parking lights to light up. I thought that i had the filaments touching each other causing them to light up but it wasn't, just a wrong bulb the previous owner put in. Thanks for the input guys!!!!
I was just gonna post to check the tailight bulbs. You get a backfeed when you use 1156 bulbs where 1157's are needed.0
