Guys c if u can help me out!!!!
chevymalibu1
288
Clearwater Florida
Right know I have 78 Malibu lowered 2" in the front and running 16x7 iroc wheels w/215/55/16 all around.
no rub problems etc..
but what I am looking to do is run 15x7 steel wheels w/dog dish caps(w/ a white stripe tire), and it already has a slight rake because of the lowered front end.
But what could I use on those 15x7 steel wheels, more for the front (where I can still get a white stripe),where I would not have rub or problems when I go over bumps like know,its perfect,and still keep a rake to it????
thanks in advance
lurchsmalibu
3,774
Lakeland, Florida
Are you looking for a tire calculator to show the dimension(s) of what you have now to do research on what size(s) you will need to go with the 15X7's? That will be easier to see what shorter or narrower tire size you would need for the front to reduce the rubbing. The backspacing between the different rims may fix your issues right from the start. :-k
