headlight conversion, 1980 malibu h4 bulb HELP??
70chevy
Member
Aug 15, 2012
6
Any one do this conversion yet?? Its from Original parts group. It is the H4 bulb kit..does not come with any instructions...any input..thanks
IDK, does it include the relay harness?
70chevy
Member
6
There is a separate harness for the headlight plug, and a relay kit for each headlight..
I'm guessing the kit will have a hot wire to run to constant +12v, and possibly a ground... my thinking is the original headlight plugs will trigger the relays.
If the bulbs are stock wattage (55/60) it's basically a swap for the existing parts, but adding a relay kit alone will make the sock headlights work much better. It's even more dramatic with H4 conversions & it's more or less a requirement if you step up the wattage.
I was going to tell you to contact Daniel Stern. He sells top notch lighting upgrades, but it's quite a bit more for the housings alone than what you're looking at...
