help ID 9" center
boostinmalibu
756
joplin missouri
i picked up a 9" for my malibu, got it apart to see what exactly i have, upon searching the casting numbers on the inside of the center, i cant seem to find any info on it
just inside the flange area it has WAA 4025-B, pinion support has 4668-B on one side, and WAA on the other
any idea what it came out of? the housing wheel to wheel mount is right at 58", factory width, has not been narrowed, small housing ends, 28 spline axles, open carrier with a 3.10 gear
desbird
347
whitehall michigan
are axle same width if so 67-72 1/2 ton truck i have never heard of a 3:10 gear 3:00 3:25 3:33 then in 200's 2:50 2:75 if the are 5lug or 4 1/2 bolt circle it is a car or possible bronco trucks was 5 on 5 1/2 circle
boostinmalibu
756
joplin missouri
bolt circle is 5x4.5, couldnt find my tape measure for the axles, but the passenger side is about 3-3.5" longer than the driver side
desbird
347
whitehall michigan
came out of some car the early bronco were same length i'll search interant to see what i can come up with with 58 hub to hub seams short may be mustang
shvrolay
Lifted from this forum: streetrodstuff.com
......forget the links listed as they are all 'dead'.
Year & Model Axle Length Notes
1965-1966 Mustang 57.25 inches
1967-1970 Mustang 59.25 inches
1971-1973 Mustang 61.25 inches
1977-1981 Versailles 58.50 inches
1967-1973 Mustang, Torino, Ranchero, Fairlane 59.25 inches to 61.25 inches
1957-1959 Ranchero and station wagon 57.25 inches
1966-1977 Bronco 58 inches
1977-1981 Granada/Versailles 58 inches
1967-1971 Comet, Cougar, Mustang, Fairlane 59.25 inches
1964 Falcon 58 inches
1967 Cougar 60 inches
1967 Fairlane 63.50 inches coil springs
1972 Ford Van 3/4 ton 68 inches
1973-1986 Ford Van 3/4 ton 65.25 inches
narrowest 9" housing
1966-1977 Bronco 58 inches 5-on-5 1/2 inch diameter bolt circle
1967-1973 Torinos, Rancheros, Fairlanes 59.25 inches or
61.25 inches
1967-1971 Comets, Cougars, Fairlanes 59.25 inches
1975 Mustang II 8" 57.00 inches
1974 Maverick 8" 56.50 inches
boostinmalibu
756
joplin missouri
it has the smooth back, so its the early style, no dimples on the housing, it is a 9" bottom two third member bolts are wrench only.
