I have dual fans and a signal fan. I would like to know what size wire, relay and fuse to use on ether set up. Should I get a relay wiring harness? Summit and jegs sell relay kits and thermostat kits should I get thermostatic switch or the adjustable thermostat probe. I would like to be able to adjust it/them to the right setting. looking to install one of them in the 78 El Camino for a resonable price. what do you run how is it run. A Diagram would be nice.
Thanks Doug
Thanks Doug
