How about this set-up in 81 Bu?
Black Mamba
68
ROCKFORD,IL
*** 227/233 @ 50 560/560 Howards Hyd Roller Cam 110 centerline ***
*** AFR 190's 2.02 1.60 ***
*** Edelbrock Performer RPM Intake ***
*** 9913 Icon Pistons *** about 9.90 compression ratio
*** Scat forged I Beam 5.7 Rods ***
*** Scat 4340 Crankshaft ***
*** 1 5/8 Headers ***
*** 1.5 3/8 Roller Rockers ***
*** 8.5 3.42 rear end ***
*** Turbo 350/3200-3500 stall ***
True street with some NMCA/Local track time about 6 times a year
bracketchev1221
1,111
Mountville Pa
Similar to my car right now. I would just upgrade to 7/16" rockers. Mine is a 355, 10.3-1 SRP piston, 7/16 Scat I beam Rods, Eagle 4340 crank, AFR 195 heads, .535/.550 231/239 hydro roller. Performer Rpm, 650, 1 5/8 headers, 4 speed and 4.10 gears.
Black Mamba
68
ROCKFORD,IL
Thanks for the feeback guys! So 3.73 gears would wake this combo up more? 7/16" rocker upgrade. What is the benefit to this upgrade? I'm interested. Nice vehicles bracketchev1221! Is the Nova the car your speaking of with the similiar combo?
Thanks,
Kino
bracketchev1221
1,111
Mountville Pa
Yes, the motor is in the Nova.
7/16 rockers are usually the same price as 3/8". It just eliminates any flex in the rocker stud that could reduce lift at the valve. I used the harland sharps on mine.
lilbowtie
1,736
Canton Mi.
Nice combo I'll be interested i what she runs. Not to undermind Bracketchevy, as long as you have good studs I wouldn't be concerned about 3/8 right now cause you won't be turning it that hard - if anything put a girdle on it. Report back.
Black Mamba
68
ROCKFORD,IL
Thanks. I have to get a couple of small parts, then its' getting put 2 gether. I'll keep u posted!
