Installed UMI upper and lower a-arms with QA-1 coil overs,double adjustable with 350 lb. spring rate..Anyone know how far to run spring adjustor up on shock body for a 1.5-2 inch lower than stock ride height ? stock type upper ball joint..Motor is a sm. blk.,alum. heads,Thanks
