how much nos for ls block.
littlefranks
543
pembrokepines FLORIDA
ive blasted a 200 hit for a while on my stock bottom ls2 now i have a ls3 gunna hit it with a 200 .lets see how long it lasts.ps ls2 still running strong in a box chevy
BIGDOGG
131
gobles mi
I have been doing some research on ls and nos. I have found a good amount of people using a 300 shot and the engine is holding but a couple of people shot it with 400 and after the hit is was a parts scattered.
Roller406Bu
396
Elizabethtown Ky
150-200 all day long if you know what your doing...
79loserbluebu
302
Illinois-60491
I'd say 150 is what most do. If it were mine anything over would be getting rod bolts
LT1_Malibu
202
Greenup, Kentucky
Like everyone else said, 150 all day long if you get the timing turned back and run the right plug.
BAD78BU
63
Texas
I have a friend that hit his iron block 6.0L with a 300 direct port shot. Not a plate, but with foggers at each port
Slp00bluess
35
Mid-Michigan
coming from the f and y body world I have seen these things hold 300 shots for way longer than you would think. then on the flip side someone hits it wtih 200 and we carry it home in a grocery bag. I would safely say 150 is the most I would use.
BAD78BU
63
Texas
All in the tune, my friend using a stand alone tank to feed the N2O setup. He has sprayed it many times with the right timing pulled and correct amount of fuel they will live.
lsxbu
New Member
Oct 21, 2013
3
im spraying 230 shot dry on cam only 5.3. holding up good so far went 6.06 @111 in 3000# car
