how to change power windows to manual?
JO-JO
Member
Apr 13, 2012
9
Conway, SC
I have an 83 El Camino with power windows that I want to change to manual. I also have an 84 Cutlass body with manual windows. Can I swap between the two? Can I simply remove the power window motor and bolt in the manual crank and handle? Anybody want the power window stuff cheap? Thanks. JO-JO
JO-JO
Member
Apr 13, 2012
9
Conway, SC
Sweet. Thanks. I was hoping it would be fairly simple but wanted to ask before I got half way in and screwed something up. Not that THAT has ever happened!
melloelky
3,654
31
mass
t5montecarlo said:
Remember to use steel rivets when putting it back together, or use small bolts. Aluminum rivets will fail; a friend tried it.
all the oem's use aluminum rivets with steel mandrels.they work,still
