HVAC guys... R12 vs. R134 and other A/C ?s
Looks like that's probably the route I'll go. Did you have to do anything to the Blazer lines?
elcaminoss84
336
Oklahoma
to get the blazer line to work you have to run a 2 inch adapter from the line to the drier or change the drier to one where the line would connect on the front instead of the side of the drier.
elcaminoss84 said:
I just finished my ac system/ serpentine setup. I used parts for a 94 chevy truck ac compressor, powersteering pump , water pump , alternator, clutch fan assembly. then used the main line to compressor from a 88 s10 blazer , the small metal line off of a 84 cutless and condensor from a cutless since the lines are on the passenger side. then used my drier and evaporator from my el camino.
You should never reuse a drier once it's been opened up...
