I need shocks and springs.
80Grand_LeMans
1,249
Peabody MA
I really need some springs up front so I figured why not get shocks and springs all around.
Looking for something cheap but something that will make a difference. I know nothing is "cheap" but I'm not looking to get some crazy race set up.
Thanks.
Gabriel VST or Monroe Sensatrac are good driver type shocks.
Also check your local parts store, ask who make thier "house" brand.
I know Carquest are KYBz.
There is a chart in the suspension section for MOOG springs which should help you choose a spring set. Maybe pick something that was for a Monte SS.
DOUG213XRJ
4,671
West, MI
I would go with a stock spring and shock form a locol auto parts store.
80Grand_LeMans
1,249
Peabody MA
Would aftermarket ones be better or do they not make much of a difference. I eventually am putting a 350 in it and I want something that will work good, not just a normal stock ride.
Fla_G-body
415
Quincy,Fl.
I got a stock suspension Bu im putting helper bags in the springs and was wondering should i just run so regular shocks or some type of drag shocks in the rear?
Norm Peterson
251
state of confusion
If the car is now a V6, you'll probably want slightly stiffer springs. Much beyond that requires knowing what you mean by "work good" (general performance, general confort, just DD, dragstrip, hard cornering of any sort, etc.), and if "good" means "good enough is OK" or "I can afford to look at better than mass-market stuff".
I can tell you that while Sensatraks are a nice comfort-oriented shock for a mild DD (and apparently Monroe still has a huge advertising budget for these things), they aren't a good choice for cars that are either lowered or fitted with stiffer than OE springs. The design feature that provides the good ride intentionally gives up some suspension control around the OE static ride height in order to get it. Lowered/stiffer just works them harder where they can't work as well to control the car. Buy them if a soft ride is your only criteria, otherwise pass.
My own recommendation for shocks for these cars tends toward Bilsteins, with KYB Gas-A-Justs being a budget-minded alternative that works reasonably well in most cases (not quite so well with 600 lb/in front springs and autocrossing - that being a case I directly know of where they don't).
Norm
DanielM
578
Racine, WI
If your on a budget I have a brand new set if gasmatic's that I could send you for the cost of shipping.
Wife say's clean up the garage [-(
Dan
80Grand_LeMans
1,249
Peabody MA
Im thinking of these:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BSN-F4B460929H0&N=700+4294925047+4294908216+4294908177+4294925130+400558+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BSN-F4B360949H0&N=700+4294925047+4294908216+4294908177+4294925130+400558+115&autoview=sku
What should I get for springs?
