Ok here it is, I'm thinking of doing a Ls1 swap into my malibu. My current set up is 350/th350 with an 8.5. I want to leave the motor FI to keep cost down and my mpg up. My questions are: Will my headers work, could i use my transmission, will my crossmember work, will i need a new drive shaft, what motor mounts will i need, will the oil pan work, what fuel pump and regulator would i need, would tuning be required if took all the accesories off the motor but the water pump and alternator, and how much do you think it would cost i found a LS1 and automatic transmission for 1500 and hour and half away from me.
Thank in advance for any help i know very little about these swaps.
