If it is the one with aluminum ends, you will need to broach it larger; very few people have done that modification. I am not certain, but the hole in your Jeep shaft may be the same size as the inside of the steering shaft, so if you have a double-D shaft that fits inside the column, it may work. It would be easiest to get an older shaft with steel ends.
