Hi,
This problem with blowing HEI modules has been going on for a few years, on my presently totally stock '79 with the 267 mtr. They generally last about 1,000 miles, then no-starto.
I've swapped, coils, distributors, added a ground from the dist housing to valve cover bolt makes no difference, modules keep blowing.
Well, we're presently down to a single driver, for my wife and myself, until I find something for her and was looking over the body ground to back of head connection. Sure enough it was loose. Thought that I was finally home free with the problem.
This morning, took it for a 20 mile or so parts chasing run, getting the Malibomb back, so she could make her hairdressing appointment. She gets in cranks it and no-starto once again. Go thru the now 10 minute module swap routine and still no starto, do it again with the last good module that I had, same deal .
During the summer a few years back, had to r&r the ignition switch and brought a Pep Boys Chinese pos. Seems like 3 or 4 thousand miles later, is when the first module blew.
Back to basics, key-on, 12V, Voltage while cranking was at first about 9.25 then increased to about 11.25. Does anyone know it this is normal?
Thanks for any responses.
