looking for estimated cost on 200r4 conversion
79izfine
2,199
massachusetts
heres my current set up i have a th350 , G/N rearend ,383 ci .... a demon carb ,rpm airgap intake and an icaman th350 crossmember ..... with out the cost of trans and converter what else is needed oh and the car is a 79 bu thanks for your time
The cost of whatever means you use to turn off/on the lockup. And either fabricate or buy a crossmember.
Some people use a toggle switch and wires to turn the lockup on/off manually, but there is a kit by B&M that does it automatically and is adjustable (which is what I have).
Not much, really. Same driveshaft.
DOUG213XRJ
4,671
West, MI
You will need a frame extention for the crossmember. Where is the 200R4 coming from.
melloelky
3,654
31
mass
bowtie overdrives.com paints a clear picture for the conversion on their website.lots of faq's on their site.
79izfine
2,199
massachusetts
Doug i found a local yard with a few monte ss thinking of grabbing one ,,,,then rebuilding but wanted to see what the cost would b wont be happening anytime soon ...... Melloelky thanks for the site ..... thanks doug
axisg
407
YYZ ( Toronto )
from the Monte SS ( once you are sure it's a 200r4 ) grab the
- TV cable
- the bracket off the back of the carb the TV cable and throttle clips into
- crossmember
- plug in the side of the trans ( lockup wiring )
- shifter bracket and linkage off the side of the trans as it's a little diff than the 3 speed
cost me $30.00 for the carb bracket, $50.00 for the crossmember, and a couple hours of time to do the 200r4 swap. Grab a new trans mount at the same time
TNTS79
1,252
Illiniois
Not trying to naysay the 200's but I would save the time and money and find an 88 or later 700R4... They are much stronger and a more adequate solution for your 383...
79izfine
2,199
massachusetts
thanks for the list axisg very helpful ,,, TNTS i have thought of the 700r4 seeing i dont know much about trannies i was told by a friend who does ,,,the gearing isnt the best set up i did see an article with a breakdown showing reasons that the 700r4 is strong ,,,,, there are other guys who are running the 200r4 behind bbc and havent had any issues then i have another buddy who hammers on his 200r4 so i figure it can handle the task ....guess i need more reasearch and education http://www.webrodder.com/article.php?AID=426&SID=6
TNTS79
1,252
Illiniois
That link you posted pretty much sums it up... The 200's can be built to handle the abuse but generally you will spend close to double what you will for a 700 of comparable strength... The 700's have a wider spread between gears but with the bottom end your 383 makes you should have enough grunt to pull through the gear changes.
http://www.oldengine.org/unfaq/leadfoot/trans.htm
1 2 3 4 R
200r4 2.74 1.57 1.00 0.67 2.07
700r4 3.06 1.62 1.00 0.70 2.29
Horsepower requirements for some transmissions
* TH350 -- 35hp
* 700r4 -- 70hp (this number seems astronomically high to me... might be true??)
* 727 -- 40hp
* 904 -- 35hp
* E4OD -- 65hp
