LOOKING FOR REAR CONTROL ARMS????
CHUMPCHANGEBU
60
LI,NY
got a friend with south side machine arms and he gave them to me with out the plates for the lower control arm do i need to be used with that plate or can i install them like any other control arm? or if i got double adjustable uppers could i use the lowers from that kit
CHUMPCHANGEBU
60
LI,NY
sounds good ramey thanks for the help i will take 1 tomorrow and send them over to you
UMI Sales
254
Hey Moe.
Thanks for sending the pics.
The trick to knowing if your southside bars will work as-is will be to verify the center to center distance and width. If they're 19-1/4 with 2.400 bushing width, they should fit the stock location.
Once they're installed, if you don't have enough forward traction, you can use our P/N 3010 relocation brackets to get the same action the original lift bars provided.
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_62&products_id=68
If the SSM bars are completely wrong, we have a replacement kit P/N 3020 which includes bars and brackets.
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_60_72&products_id=83
As for the uppers, to put them in, measure the center to center on your factory uppers and adjust them to the same length as a starting point. From there you can adjust your pinion angle to optimize street driving or drag launch. Hit me up on here when you get to that point and we can get you dialed in.
Hope this gives you a good starting point.
ramey
